Help
My parking break on my 2004 XJR seems to get suck on the ON mode. Cannot release it unless I mess with it for about 15 minutes. Sometimes it works and sometimes it is just in stuck mode. Does not matter if I put it on, it seems to be automatic from what I have heard. Is there a release switch anywhere? In the trunk or ?
Fuse number will be listed in the owner's manual.
PB comes on when you remove ign. key, and off when you insert key.
You should be able to hear it working with door or window open.
Also you can manually switch it off by depressing chrome switch on centre console and
on by pulling it up.
Search this forum for recalib procedure.
Skarre
04-17-2016 02:55 PM
michaelodonnell123
02-25-2016 01:15 PM
