Help 2004 Transmission fault
looking a purchasing a 2004 xj8 vdp. Drives beautifully at all speeds.
Accept when at around 70 mph when using the kick down. It feels like it changes down too many gears. 6500 rpm. If seems to try and change gears but slips. Transmission fault. Light comes on. Goes into 3rd gear and won’t change. Stop and cycle the ignition puts light out and trans operates normally.
It only does it when pinning the gas pedal to the plot. It drives normally otherwise. It’s got a 120000 Miles full service history up to 100,000 at jaguar. I can pick it up pretty cheap but can’t afford to do a transmission. Hoping it’s some thing cheap. Lol
Received 2,662 Likes
You can service it yourself, or have a Jaguar specialist perform the work.
Here is a listing for the oil change and service parts:
Oil change kit for 6HP26/28/32
Sphillipss
36
01-04-2015 08:52 PM
merlin637
07-16-2014 12:44 PM
steffenvh
01-10-2010 11:45 PM
