Help !
Help !
Guy's I have a 2004 XJR .When I accelerate hard the car will buck and hesitate like it's not getting gas. It has a p0171 code I have replaced the maf sensor, first with a aftermarket, and the oem. I replaced the o2sensors, fuel filter, both cats and the pcv. I smoked tested the car, and found and fixed some leaks it did get rid of a 0174 code, . My Indy mechanic said it must be the intake manifold gaskets leaking. Could it be anything else? before I start a big job like that I wanted ask the board
I had codes P0171 and P0174 on my04 XJR with 154k miles. I took a look in the throttle body and it was bad. Black gummy and crusty in there. Removed it cleaned it as well as i could. About 2 cans of TB spray. Reinstalled with a new gasket and all is great now. It was so bad and gunky on the backside and all down the opening under it. The only other things I did before that with no change in code results was cleaned MAF, smoke tested no leaks, and I bought a fuel filter but never installed it.
My car was bucking and kicking at 3000rpm but also displaying restricted performance at the same time. Basically rev limiting.
chopr
06-09-2015 03:46 PM
