Help.....can't pair iphone with 04 Jag XJ8!
you say 2004. I don't believe it will have Bluetooth. Mine is 2005 and doesn't, although it has the Motorola integrated phone. I think Bluetooth arrived with the X358.
If you email owner services at Jaguar with your VIN they will tell you the as-built specification and options fitted.
Welcome to the forum cfrazier9, when you get a moment stop by our new members area and introduce yourself ==>> New Member Area - Intro a MUST - Jaguar Forums - Jaguar Enthusiasts Forum
2004-built XJ's (2005MY) did not have bluetooth fitted from the factory.
Unless someone retrofitted the system it will not have bluetooth at all.
It is possible to retrofit the factory system from the 2006MY onwards vehicles, although some custom wiring will be needed. I just recently did this with my own XJR, had been sitting on the parts for a while but it cost me something like $400 to source them from a wrecked vehicle.
A kit like this https://www.jaguarforums.com/forum/p...e-x350-146957/ is the older factory system.
There is also a newer module that is much simpler and does not require the wiring modifications to work with an older car.
PigletJohn (08-16-2015)
I wouldn't be too worried about compatibility. The kit I just retrofitted into my XJR (same one that was in that for sale link) came out of a 2006 XJ and it works fine with my iPhone 6.
The factory bluetooth setups are only for phone functions, if you want bluetooth audio streaming from your phone or other device then have a look here https://www.jaguarforums.com/forum/a...ptical-134964/
FS[Western US]: XJS Wiper Motor Upgrade- 76-88 - Electrolux Style
XJsc-guy
09-02-2015 12:43 PM
