Help Needed
Help Needed
Good afternoon everyone. When I was given my 07 xjr jaguar in October, one of the issues that I had with it is that the windows will not come down. I've done what I know to do but I'm not able to get the windows down or to even move at all. The red light on the master switch on the driver side is lite up red so there is power going to the window switches. I have checked them with test like as well. I have changed the switch but that didn't work either. So can anyone on the thread tell me what I should do next? Oh I'm getting a code in the GEM saying short to ground in passenger side window. It doesn't say which door window though.
The second thing is the wipers only work on high. None of the other settings work. How can I tell if this is a motor issue, a relay issue or the switch? Any help that anyone can give me on these issues would be greatly appreciated.
Wingrider (02-29-2024)
I'm looking at schematics for door windows; short-to-ground would lead me to think (one of) the window motor assemblies has the short to ground. Each window motor assembly has a ground wire in the connector - its the black one. Checking for short means removing the door card, which is a PITA but not too technically difficult. I would start with front passenger door, disconnect connector at motor assembly, and see if short goes away. If code specifically says "passenger" that refers to front door (rear would say rear).
Good afternoon Ctsemicon, I hope this email finds you with all things being well on your end. So I went back and checked the code and yes sir it's passenger window that is short to ground. The code is B2196: Passenger Door Window Glass up/down Power Circuit-Short Circuit To Ground. So I will take your advice and remove the door card. Then disconnect the connector at the motor assembly and see what I get. Now if it goes away, what is next, do I plug it back in or how do I further go about trouble shooting? And if it goes away, do you think the other windows will begin to work?
Do you have any knowledge on my wiper situation? If so, please share.
Good afternoon Wingrider, I hope all is well on your end. Hey by chance can you please tell me where the major grounds are? I've seen the one from transmission to frame but where are the others. I've been looking but I guess they are not where they normally would be on American made cars and if they are, mine are gone. So maybe you can point the major ones out for me.
This information is clipped from the schematic diagram which you can download your own copy from JagRepair.com - Jaguar Repair Information Resource
