Help Needed Designig Fuel Rail Connector
Help Needed Designing Fuel Rail Connector
In my enthusiasm to replace all hoses, I removed the fuel rail connector, effectively destroying it.
This is how I plan to replace it. I really don’t know my * from 1st base about any of this; so your help is greatly appreciated. If you know a better material or method, please share it.
In the picture is the semi-rigid, Multi-layer, OEM hose. It has a thin lining of nylon or some other plastic-like material. It fits nicely onto the sides of the supercharger front support. You can see the valley hose runs underneath the support.
I plan to use: (https://ttmotorcar.com/collections/f...-hose-blue-1ft)
TT Racing: 8MM ID Nylon Stainless Steel Braided PTFE Fuel Hose Blue (too bad it won’t be visible.)
Ideal for racing cars, with E85 fuel lines, high-pressure fuel lines, and automotive applications, this NYLON STAINLESS STEEL BRAIDED FUEL HOSE has a stainless steel braid for outstanding durability and a Nylon braid outside for maximum protection.
Product Specs:
Product Specs:
- Suitable for gasoline and E85 mixture
- Special outside finishing of Nylon with ultimate corrosion resistance
- Outer Diameter (OD): 11.80 mm
- Internal Dia (ID): 8mm
- Length: 1ft (I need 2’. They have it in too long packages also.)
- Pressure rating: 1000 PSI Working, 5000 Burst PSI
- Temperature rating: -100°F to 450°F
- Lightweight and easy to install
- High bending capacity to mold for enclosed space
Found The Parts
Found a hose that likely exceeds pressure, temp specs; has a similar Nylon liner. The difficult part was finding something that pushes on. It is not as rigid as the original, but I don't think that will make any difference the way I am running it. The red jacket is a heat shield. Am running it under the snout of the SC. Shorter distance &, I think, a better installation than the original. We'll see.
04Xjrsteve (07-18-2024)
Thanks, Clubairth. You make me laugh because I thought the whole world had heard me conducting a symphony of hose harmonies under the hood of my R!. Replacing all the hoses I can get my hands on! In my enthusiasm, I ripped the rail connector off! Hence, the need for...
I would say that a goodly number of the hoses I'm replacing are ready to let go.
Thanks for the chuckle & best regards,
Steve S.
Steve S.
Hey I have been watching your work and it's coming along great!
Just could not help myself as you know that under SC hose is a real weak point on the 4.2L SC engine. It's a shame too because the hose is only about $20-$30 but all the labor and gaskets makes it a difficult and somewhat expensive repair.
Is that hose still available from Jaguar? It's not a common failure point?
Looking in JPART it does not show that hose to a separate part and is included with the entire fuel rail?
So your hose replacement is probably the better way to repair this.
04Xjrsteve (07-20-2024)
Thanks to good folks like you, Clubairth, I am able to move forward. I've really learned a lot; however, I started pretty close to zero.
The infamous valley hose is available, I have been buying from Harper & a young fellow named Carl is just wonderful there. I will do a shoutout more properly when I get caught up.
The fuel rail connector was made as a single part which includes the SS rails. This part is no longer offered by Jag. There are some used ones available on eBay.
Have a great weekend!
Steve S.
Steve S.
There are a lot of really cool, smart and helpful people (like you fellows!) making hoses for planes, trains & automobiles. I found several companies making them for race cars to be most helpful. Several tech support people actually had experience doing exactly what I was attempting!
Any of you following my posts over the years know that I know little more than **** from Shinola about auto mechanics and the little I do, I learned right here on this forum. This is a round about way of saying that my fuel rail connector is a trial & not a recommendation. If you find yourself wanting to do this, I know you will seek wiser counsel.
As I said, in my enthusiasm to replace every hose, I removed the connector part of the fuel rail part. (DON"T DO THIS!)
I thought that because of the volume of work I was engaged at the time, that I would fabricate something & replace the Fuel Rails with the Connector when I had to do something with the injectors... Hopefully, never; but it is inevitable.
When I saw that I could run the hose over the snout of the supercharger, I decided to do so for 2 reasons: !. Easy to inspect the hose. 2. Much easier to replace if necessary.
In addition to worm drive clamps on each end, I used:
https://www.redhorseperformance.com/...ush-lock-hose/
So far the pictured connector has worked for 2 hours of driving & it works!
Thermite (08-05-2024)
Terry007
09-07-2021 05:33 AM
