Help - Rear Control Arms - Interchangeable parts??
I have searched the forum and have read many threads on which parts are interchangeable between S-Types, Lincoln LS & Thunderbirds. The only part I have a question with are the lower rear control arms.
Some say the 02 Lincoln LS arms such as MOOG Control Arm Part No. RK621951 & RK621952 have fit their 04 but not the 08. They say the 04 was a direct fit but the 08 had to be modified. One reasoning is that there was a change made in 07. Does anyone know if this is correct? I have a 06 and looking for anyone with experience if these Moog arms will fit a 06 directly?
i think the rear knuckle changed in the middle of 05. i have dormans arriving in the mail today, I can check if it's a 54mm or a 59. almost 100% the mevotech and moog are coming out of the same chinese factory.
aftermarket arms sold for the 03+ lincoln LS and tbird are a scam, they're identical to the ones sold for 00-02.
If I just had to modify the cradle a bit for the shock that would be fine. However if I needed to modify the spindle mount as well I should probably try something else. From the posts I read there was a change in the shock mount design mid production causing some to be modified but no affirmative answer as to when.
As far as the rear spindle mount I am a bit perplexed, the same spindles are sold to fit 03-09 unless it's an XJR where there seems to have been a change starting in 08. I can see changing in mid year 07 but not understanding why an XJR of 06 would not be a direct fit as an 04.
I have a 06 Vanden Plas so I guess I will find out for sure Monday when the replacement takes place. It was just one of those things where you start searching for answers online and you keep digging and digging until your totally confused. After Monday I will have replaced the entire suspension front and rear suspension.
![Smile](https://www.jaguarforums.com/forum/images/icons/icon7.gif)
On these Moogs I measured it at 54mm which would be a direct fit to the knuckle on my 06. I will update Monday when they are installed as I hate to read posts that are never updated with the outcome one way or the other.
I am ordering the direct fit. Wanted to give it a shot since I could not find a definitive answer in the previous threads.
