Help: Sulfur/exhaust smell inside car when HARD acceleration
So, I had a code for a o2 sensor on bank two, replaced engine light off. This car as no leaks, well atleast I dont see anything on garage floor where I park it.
Since I bought the car, when you really give it some gas, there is a sulfur/ phosphorus/smell inside the car. I figured it had something to do with the o2 sensor. Changed it, and it still does it. DOES NOT idle ruff and seems to run like a champ otherwise...
Any ideas?
I am thinking cats but after doing some research around here I am not 100% on it.
Any ideas?
Exhaust smell after full throttle run
I have the same problem with my 07 XJ8. Every time I stomp it and run it up to 80-90 mph the smell comes in the cabin. If I have the AC running I don't get the smell.
I suspect the AC is pressurizing the cabin and the exhaust can't get in. I've had the problem since I bought the car almost 2 1/2 years ago. My car runs fine, plenty of power and great gas mileage. I don't detect any odors when driving "normally".
This has been reported on the XK forums, as perhaps an opening somewhere letting exhaust into to car.
Regards,
Don
Regards,
Don
BrentGardner
28
04-26-2024 03:08 AM
Sshenton1975
08-30-2015 09:29 AM
