help window rolls down by itself
i have an 04 ---when i operate the rear passenger window from the drivers master switch it rolls down -even with switck held up --i even put in a spare switch with the same result----------window works as normal from its switch---any suggestions ???????-------thanks
In looking at the wiring diagram, the window switches for each window on the drivers door pack and the individual doors are tied together, which means that the wiring for the up switch position on the drivers door switch may be broken or have a bad connection between the drivers door and where it ties to the individual door switch.. Now a matter of tracking it down, yea!
blackenedindustries
09-30-2015 10:17 AM
