High pitch windshield noise
You probably nailed it.
You could try sealing from the glass to the body and over the trim mouldings all the way around, and including the little gaps at the ends near the doors using masking tape. Then go for a drive. If the noise is gone, you know for sure.
Then it is just a matter of taking it to a glass shop to get it resealed.
glenlake (04-24-2011)
You need 10 posts in total.
But, it basically says:
1. "Clean area behind the flip seal in preparation for the glazing compound application."
2. "Apply 3M™ Auto Bedding and Glazing Compound 08509 under the flip seal to
prevent vibration of the seal at high speed."
The flip seal is the rubber seal around the windshield, and it vibrates at high speed. The sealant holds it down.
If you are a dealership mechanic doing this on warranty, you are allowed a whole 12 minutes to do the job
CaneCounsel007
11-13-2015 09:05 PM
hen555
09-07-2015 11:13 PM
