Hit a curb- had to have Jag towed
Over the weekend my husband hit a pot hole right as we were about to turn. The passenger front wheel went over a big curb- approx 15 feet of scraping. The car made a horrible noise, blew smoke, and didn't stop immediately despite brake pressure- probably rolled another 10-15 feet. We turned it off, and looked for damage, couldn't see anything. It went into restricted performance and limped home. The following morning it sounded even worse, and blew nasty smoke again, this time the check engine went on, and it died shortly after.
I had it towed to the shop this morning. My husband thinks it knocked a sensor, but I don't know why that would make it blow smoke, or fail to stop. Any ideas what we might be looking at repair wise?
Thanks,
Trish
Thanks,
Trish
I think you need to steel yourself for a significant cost to repair. Apart from the engine problem, there is likely to be suspension damage, with wheels out of alignment, even damaged, and so on.
If you can sue the highway authority for neglecting their job, then you could get some or all of this back.
Rlover
03-30-2016 10:04 PM
