Horn replacement
Did you ran your Jag in a flooded street? If that is the case more likely, the other horn would also fail soon. Since you are changing the horn might as well install in pair. There is a pair of Fiamm Freeway Blaster for $23.95. Made in USA
https://www.amazon.com/FIAMM-74100-Horn/dp/B000DLBIGG/ref=asc_df_B000DLBIGG/?tag=hyprod-20&linkCode=df0&hvadid=312681740304&hvpos=&hvnetw=g&hvrand=10212615696830170565&hvpone=&hvptwo=&hvqmt=&hvdev=c&hvdvcmdl=&hvlocint=&hvlocphy=9061128&hvtargid=pla-571188306615&psc=1&tag=&ref=&adgrpid=61040318086&hvpone=&hvptwo=&hvadid=312681740304&hvpos=&hvnetw=g&hvrand=10212615696830170565&hvqmt=&hvdev=c&hvdvcmdl=&hvlocint=&hvlocphy=9061128&hvtargid=pla-571188306615
No submerging in water...when i purchased the car last year it was clear something was wrong. Only the high pitch horn works, which sounds horrible for such a status car. I purchased a used pair on the bay and will tackle this over the weekend. I'll report back.
