How To Access Starter Bolt Closest to Engine Block?
Received 13,349 Likes
Hi eadams928,
Welcome to the Jaguar Forums! It's great to have you with us.
I have moved your posts to start your own thread with a title that will llet other members know the nature of your inquiry.
Unfortunately the Workshop Manual is not very helpful regarding the removal of the starter. This is all the instruction it gives:
I assume you've tried a deep socket with a universal joint and an extension of suitable length? If you have 1/4 inch drive sockets and extensions they may help if you can apply enough torque to loosen the bolt or nut. If I recall, one of the starter holes is secured with a bolt and the other slips onto a threaded stud and is secured by a nut.
Hopefully other members with better memories will be along to help.
Once you get your starter replaced, please visit the New Member Area - Intro a MUST and post a required introduction so we can learn something about you and your Jaguar and give you a proper welcome.
Cheers,
Don
Cheers,
Don
jaguars4r
05-06-2015 08:44 AM
Skelly
04-10-2015 05:14 PM
Hex Type
04-04-2015 10:28 AM
Nucengineer
05-21-2014 08:46 PM
H20boy
08-13-2011 12:28 PM
