How can I open the trunk?
Old 01-24-2014 | 07:19 PM
tamscash's Avatar
Exclamation How can I open the trunk?
How can I open the trunk of my 2000 Vanden Plas. The key won't work, I don't have a remote and the car is stuck in valet mode.
Old 01-24-2014 | 07:58 PM
avt007's Avatar
Welcome aboard! You'll find this to be a fun and friendly group. Dig in, poke around, and ask lots of questions.
If someone's post is helpful, please thank them using the "thanks" button.
If you have good information on a problem, please share it.
Post some pictures of your car when you can.
As for your trunk, do a search for "trunk" in the X308 forum (BTW that's where this thread belongs) and you'll find lots of info. Basically, remove the licence plate and use a long screwdriver through one of the holes to pop the mechanism open.
Does the key not turn, or?
Old 01-24-2014 | 09:21 PM
tamscash's Avatar
I read on here about using a screw driver and can only see a screw on the left side of the right bottom hole. Is that where I need to look? If I could get it out of valet mode I could use the button.
Old 01-25-2014 | 04:02 PM
meirion1's Avatar
Have you tried locking and then unlocking the car to get it out of valet mode?
Old 01-25-2014 | 05:47 PM
avt007's Avatar
Under the plate there are some black plastic bits of tape over some holes. I had luck going through the bottom left hand hole and feeling around with a screwdriver.
What happens when you try the key?
Old 01-26-2014 | 05:42 AM
Fraser Mitchell's Avatar
BTW this is not the forum for your car. Try posting in the X308 forum
Old 01-26-2014 | 09:36 AM
tamscash's Avatar
It doesn't turn all the way. It has opened it in the past but doesn't anymore
Old 01-26-2014 | 10:12 AM
tamscash's Avatar
yes but it didn't work. any other suggestions?
Old 01-26-2014 | 01:30 PM
avt007's Avatar
Spray WD40 or similar lube into the key hole and work the key back and forth.
Old 01-29-2014 | 08:14 PM
tamscash's Avatar
got the trunk open! sill in valet mode.Thank foe your help!
BadKat174
05-26-2023 01:29 AM
bigblackcat3
XJ40 ( XJ81 )
09-14-2015 05:03 PM
DuhCar
09-11-2015 11:58 AM
findre
09-10-2015 06:46 PM
speacock
09-10-2015 01:14 AM
Quick Reply: How can I open the trunk?
