How to change the transmission pan/filter and fluid on an X350
It's an Allen 8mm....make sure it's a snug fit!
I had to go through a whole rigamarole to extract a damaged
plug....because some stooge couldn't use enough brain power to do it properly!!
Torx screws for the pan itself.
before trying to remove the Torx screws, it pays to go around
with bit in holder and use a hammer to tap each screw a couple of sharp
taps....they will loosen easier and less chance of snapping off screws
heads which happens occasionally....then it becomes a PIA! ;o]
Wes Steenrod
09-06-2015 06:52 PM
