How do i reprogramme a key remote fob for an XJR 2005?
#61
So I tried again
1. Open the driver's door
2. Hold the high beam
3. Insert key and turn to position 1
4. immediately flash 4 times and hear the beep 1 time
5. I pressed any button once(beeps) quickly turn off the ignition (beeps) and close the door.
Seems the program was successful but the module doesn't hold the programming longer than a few seconds after reprogramming? are both my keys broken then? i put new batteries in both FOB
very puzzled!!
very puzzled!!
#62
#64
#65
#66
#67
I finally got one FOB to work...I am starting to think if the other one is broken...hmm...in any case thanks for the replies.
#68
I have been working on this for a few days now. My fob stopped working last week - XJR 2004. Had it happen before ( 6 months ago) and bought a replacement off Ebay and reprogrammed it ok. This time, bought another off Ebay, and went through the stages outlined - got the beeps in the right places. I also did it with the original fob. It seems to code ok, but only worked ONCE. Then it seems to lose the coding. BUT what is odd is that if you then drive the car it will allow it to be locked remotely just once. SO it seems to keep the coding but only work sporadically. FYI I only have one working key.
Am very confused now as I have I think eliminated human error or fob issue. So any ideas?!!! Its a real PITA as I have a young child and need to get her into a car seat in the rear. Assume it is car-related so where can I start looking/. Cant afford trip to the dealer with this one just yet! Help much appreciated.
#69
#71
My 2005 X350 key fob quit working. After installing new battery for dead one I reprogrammed remote several times (using your great directions & advice). Now all the buttons work except lock button. I suspect fault in switch/board and will probably live with this for a while and then buy another fob to see if it will work. Does this sound reasonable?? Thanks.
#72
