How do you detach trans oil cooler lines?
I have searched for this however cannot find the answer.
Today I changed the oil and filter in my 2005 XJR and while I was under the car
checked out the transmission cooler lines.
I want to detach the lines where they enter the transmission. How is this accomplished?
I have seen pics of the actual lines out of the car and the ends look as if they are a press fit with two O rings on the male "plug" that goes in to the transmission.
The reason I want to do this is to flush the transmission oil cooler radiator when I do a transmission fluid change in about a month.
I am used to the screw in type as well.
Searching on-line I see adapters available for this transmission that take screw on hose fittings and they are held in place by a flat clamp that is screwed on to the transmission housing.
Considering that I want to flush the trans oil cooler is it easier to access the lines where they go into the radiator?
I probably will pull stuff apart to look.
