How do you remove the left AC vent on drivers side?
Parts lists it as an entire vent assembly. Do you still have the piece or is it lost? If you still have it you can reattach it if you don't have it then to remove the assembly, you have to first remove the center console, the hump in the middle of the wood dash, then gently pry the wood dash cover off, then remove the instrument cluster, then remove the vent. The reason for all of this on the driver's side is because part of the vent is screwed in behind the cluster, silly engineers, as this apparently is a common repair. The passenger side is a piece of cake.
If you still have the button and depending on how it came off, you don't necessarily need to do any of the as it is not too hard to just press it back in place, you'll probably need something to hold to the back of the black plastic mount the button attaches too. Just press it on and it should stay or use a bit of glue.
Good luck.
CharliePar (02-15-2018)
99xk8guy
06-05-2023 06:28 AM
