How Does The Pictured Fastener Come Out?
Old 03-13-2024 | 04:31 PM
04Xjrsteve's Avatar
Default How Does The Pictured Fastener Come Out?
In the center of the plastic screen under the wipers is a metal threaded(?) bolt with a #10 head. I've turned it what seems to be a reasonable amount & it doesn't want to come out. Any suggestions? Thanks Steve
Old 03-13-2024 | 04:33 PM
04Xjrsteve's Avatar
OOPS! My bad; from my photo it is a round head screw/bolt!! Don't get any older!!
Old 03-13-2024 | 05:15 PM
Pete M's Avatar
It's a plastic trim clip. Slide a trim removal tool under the small head and it will pull out vertically.
I don't think it's in the right place. The clips normally on that cover are very low profile, and the square head recesses into the body. (C2S13233)
Others in that area are XR87160
Possibly that clip should be for retaining the plastic auxiliary bulkhead at the rear of the engine bay..
Pete M
04Xjrsteve (03-14-2024)
Old 03-13-2024 | 05:35 PM
04Xjrsteve's Avatar
OK; light finally turned on. It is plastic and the center piece pulls up allowing for it to come out. Problem solved.
Old 03-14-2024 | 09:20 AM
04Xjrsteve's Avatar
Thanks, Pete.
Our posts "crossed in the mail". I suspect the clip was installed at the factory since the cowling has not previously been removed.
jobagadonuts
09-16-2023 08:09 AM
wouldbeowner
37
09-03-2021 08:34 PM
ramskifast
05-15-2017 12:39 PM
phaelax
04-19-2014 02:38 AM
timsalyer
11-28-2013 02:22 PM
Quick Reply: How Does The Pictured Fastener Come Out?
