How To Find The Correct Bulb Replacement For My Car?
2004 XJR X350
The low beam is occasionally flickering. I have attended to the 3 ground posts as described in the sticky & it still flickers. I would like to replace the low beam bulb on both sides.
When looking at the low beam from the front of the car, you can see a small circle (projector?) in it.
Does anyone know how I can find a description of the bulb I need to purchase? Ideally, there is a way that I could use the VIN to be sure? I realize that I could remove the bulb & check the bulb itself; however, I would like to do it all at once.
Thanks for your help,
Steve
Steve
The following 2 users liked this post by JoeDredd:
04Xjrsteve (05-06-2023),
rsa760041 (05-08-2023)
2004 xjr X350
OK, Easily found D2S bulbs, but not the D1S ones. There is more than one light "body style" listed for the recommended bulbs for my car.
So, I thought it would make sense to pull the bulb out in order to be sure I purchase the right one.
Well, the metal holder was easily pushed forward & the cover is loose. However, something at the bottom is preventing it from coming off. Actually, it is "off", but I cannot take it out because it is being blocked by something at the bottom.
I will go back & review this & other posts because some mentioned removing the bumper. Sounds crazy, but it's a crazy world!
OK, having reread the link kindly provided by Mark, I have decided to wait until I have the time & gumption to remove the bumper. Mercifully, the bulb only slightly flickers on occasion. Does anyone know if the bumper cover is what is blocking the cover from coming off?
From a previous post from JAHammer, I see that the OEM bulb is the OSRAM 66144. Amazon has 2 for 100 bucks.
I feel comfortable ordering these even though there seems to many others offered for significantly less.
Any & all suggestions are much appreciated.
https://www.amazon.com/OSRAM-XENARC-...94155301&psc=1
Hi Steve,
I always go for Osram as my brand of choice when I need to replace bulbs on one of my cars, because I am very satisfied with the quality (OK, it might also be that I am biased because I live in Germany...). My alternative choice would be Philips, they also make high quality bulbs, but price wise they are very similar.
Osram also has an improved version of the bulbs called "D1S OSRAM - 2023 NEXT GEN - NIGHT BREAKER". They are a bit more expensive and they might be a bit less durable, but I find that the performance is really better in comparison to the OEM version. It's the ones I have bought when I replaced the bulbs on my car.
Regarding the stuck cover, it comes off at the back, so I do not think that the bumper cover has anything to do with it. The bumper cover only needs to come off if you want to remove the headlight assembly. When I replaced the bulbs, I had the bumper off anyway because of some other work I did on the car and so just had removed the headlight assembly for the replacement.
I will check today whether I have issues removing the cover and will revert,
04Xjrsteve (05-07-2023)
Thanks, Thomas!
What you say about the bumper cover makes sense. I believe my R is not as long as your Super V-8. I wonder if there is less space behind the cover in the R? Still, it doesn't make sense that since the cover is off, it can't be easily lifted out. The hangup seems to be at the bottom.
I will check out the Next Gen OSRAMs.
Hi Steve,
my SV8 is a SWB, same as your XJR, Here in Europe they sold the SV8 in both SWB and LWB forms, and you could get the LWB also with the smaller engines. But even as a LWB the space behind the cover would be the same, as the LWB has about 10 cm more legroom in the rear. This means that the cars are identical from the front to the B-pillar, then you see the difference in the length of the rear doors.
I have looked to the covers on my cars and removed the one on the right hand (passenger) side. Yes,the space is tight, also because of the earthing studs are placed a bit stupidly so that they are in the way, but I was able to remove the cover. There is a metal loop at the bottom that holds the bottom of the cover (you can see the metal loop in the second picture and the bottom of the cover on the left in the third picture), I was able to take out the cover from there by rotating it. Difficult to explain, you need to try.
I have attached some pictures, I hope that they help.
By the way, to push back in place the metal holder to fix again the cover, I needed the help of a screwdriver as a lever.
Best regards,
Thomas
Best regards,
Thomas
Thanks, Thomas. Above & Beyond!
Not able to find the bottom clip on the LH low-beam, I tried on the RH low-beam. No luck finding it on either. In both instances, they feel free, but something at the bottom is retaining them. I tried jiggling up, down & sideways. Were you able to get your fingers low enough to find the bottom clip?
Low-beam LH cover.
Low-beam LH cover.
Hi Thomas,
Tried about the only thing, a screw driver, that will fit & the angle doesn't work to get a bite on the retaining bracket. How did you remove the bottom clip on yours? Did it just come undone when you pulled up? If I didn't see that yours came off without removing the entire light, I would swear that I needed to remove the entire light assembly.
Thanks,
Steve
Thanks,
Steve
As I recently had to take out the headlights of my car to change the ballast modules, maybe a picture of the disassembled lights help to get a better feeling for the removal process:
You can see the bottom retainer for the cover that Thomas mentioned on the lower right side. This on is not removed but the nose of the cover visible in the second picture is inserted into it from above. Then just push the cover into its sealing ring all around and slip the upper retaining wire on to hold it back.Make sure this is really tight, otherwise you get moisture into the lamps over time.
The following 3 users liked this post by Aix:
GOODNESS, WOW & THANKS to my newfound Teutonic friends! When you find yourselves in Seattle, drop me a PM & we will show you the town!
Thanks to your generous help, I believe I can do this!
When I tackle this, I will allow a day just in case I need to remove the entire assembly. My hands are not small & if I'm going to lose my religion, I would prefer it not be over a couple of light bulbs!
Thanks for brightening my day & hope you have a good one, too.
Steve S.
Steve S.
but they'll probably have grown out of this when the thing fails next time
Steve S.
Steve S.
Hi Steve,
you're very welcome, and thanks for your kind offer!
The job is doable. Sorry if this comes a bit late, but as there are warnings about working on HID lights because of the high voltages involved, just to be on the safe side I would suggest that you disconnect the battery first thing.
Good luck!
Best regards,
Thomas
Low beam headlight bulb on a jaguar xj 350
2004 XJR X350
Steve
Steve
- Low beam headlight bulb on a jaguar xj 350 the bulb you need is a D1 R I changed min on my jaguar xjr x350 2005 from Robert rawle South Wales UK Britain
