How to lower your X350
#41
i tried to follow your instructions but SDD keeps asking me those stupid qualifier questions about modules fitted in my 05 XJR,,
please, help,,
#43
Just for some update that the washer mod is still working fine so far with no ill effect. Other than need reallignment which I haven't done it yet since the wear is too great on the tire to even warrant it now.
Will get a 4 wheel alignment next year when I get 4 new tires sometime next year.
#44
Not many have the SDD and cable nycturbo...fly down here, I'll help you out. Its what...70 degrees here, maybe you need a break from the weather?
KJ217, why not just answer the questions and let it move on to the recalibration? I have to do it sometimes when turning on a feature or vice-versa. Sure, its redundant, but probably has some reasoning behind it.
#45
#46
It is a very slow process, I've gotten impatient more than once, but it does eventually complete. I've had mine chugging along in the middle of 'reading' say the ECU, and if the car isn't actually running, it 'loses communication' and I have to start over, so I just have the engine running when I come to that particular question and i've no problems since.
#47
#48
#50
You should ask in the regional section as well North East US - ME NH VT MA RI CT NJ NY PA - Jaguar Forums - Jaguar Enthusiasts Forum
#53
I am pretty sure you can't, because as soon as you go into the programming, the system purges all of the air and goes to its 'default' height. W/o the compressor, you won't be able to add the needed air. How do you get your ride to remain level when it purges at certain times (to remove moisture)?
#54
Great write-up/post Cambo as for the SDD IDS taking its time it might be something to do with the charging system fluctuating
Just had a guy come out and put a tune in my diesel van he connected the battery to a very high amperage high quality charger as well as his laptop just to make sure the power supply to the cars computer and his laptop where perfect
Just a thought
Just a thought
#55
Doc, that is the correct procedure. Sounds like the guy you had out knew his stuff
Cant remember if i read it in the SDD manual or the SDD help but it does mention connecting a PSU (not a changer) at all times
The Factory one puts out a steady 13.2 Volts
I use a switch mode PSU when using the SDD
240 Watt 12V 18A Switchmode Power Supply - Jaycar Electronics
In the pic you wll see a adjustment knob. I turned it up to 12.2 Volts
the PSU can supply 18 amps, more than enough!!
I also use it as a battery charger
34by151
34by151
#56
#57
I read that, when using IDS-SDD, JLR instructs using quite a powerful power supply, 55 amps and 13.2 Volts, Midtronics or alike.
This ensures a high voltage during any reprogramming process.
Unfortunately such a power supply is not easy to source in the EU and is expensive.
A fully charged battery without additional external power supply would deliver around 12.6 Volts.
Is the suspensions reprogramming long enough and/or power demanding that it may exhaust the battery if not assisted by an external power supply during the process (how long is that process)?
And would 12.2 Volts/ 18 Amps (seems quite low, especially voltage) additional power suffice for not putting at risk that suspensions reprogramming?
#58
Is this what is needed to do it right? New Vxdiag VCX Nano OBD2 Code Software V141 for Land Rover Jaguar 2 in 1 | eBay
#59
https://www.jaguarforums.com/forum/x...?highlight=sdd
paydase (03-31-2016)
#60
I think you are too low on both voltage required and current capacity depending on what SDD activities you are using. Have a look at this thread I posted for alternative voltage maintainers.
edit: sale is over, unfortunately, seems that it was a liquidation, reason of the low price.. I will have to search again. Thx anyway
