How to program Climate Control Module
#41
Yes my car came without screen and I got the harness, navigation control module and screen.
After I installed them, they works fine but not the climate control. I can not control my climate. I think it’s just happened like you before.
so if I replaced the climate control module that is under the dashboard into a ccm that was from a xj8 that equips Nav, will it work?
#42
#44
#45
You can use SDD to program any module in the car, I made a thread a while ago about my climate control system bugging up and acting like it was a system from an X-type. I chose MANUAL reconfigure of either the amplifier or some other module (i forget). Selecting Manual allows you to select vehicle specific features which then writes into the ECM's VID memory.
#46
So i have to get the SDD system from ebay. But how that works? I mean all I need is the software, latop and OBD2 cable that connect the latop to my car?
#47
You need an XP based laptop (or one that runs XP on virtual machine) you need a compatible OBD2 cable (Mongoose or equivalent) and the SDD software.
As long as you know your way around a computers its rather straight forward. The software itself is dimwitted and slow; and will freeze up occasionally.
If you are doing any ECM/TCM reflashes, its usually recommended you source a HIGH QUALITY power supply such as ones used with RF radios, as they produce stable voltage with little noise
#48
#49
https://video.search.yahoo.com/searc...70&action=view
Have a look at the above to begin with.
I suggest you do NOT try any reprogramming until you have done a lot of research and then only with an approved battery support product as already mentioned.
#50
#51
Finally got it up and running, thanks to the wire harness supplied by jostaffs, over on the jaguarforum.com, and the help of motorman and Sean W on this forum. Turns out, the XJR's CCM does not need to be replaced, just tell the car that is has navigation. U wish I had taken pictures of the process, however, I'm willing to review the process I used and provides the details to anyone interested. I know that this SAT/Nav system is outdated, but I like the way it looks in my car. Thanks so much..
#52
That being so you have to follow the directions that come with the after market unit.
I must admit I do not understand your objective?
#53
Since I started with a non-navi system, all I had to do was install additional wiring and program. Like jackra_1 stated, you should follow the aftermarket instructions, since you won't be using the fiber optics.
#54
I'm trying to install a button style control panel for climate control, then after market stero...need wiring info for panel
#55
#57
Ok now I understand.
You need the wiring diagram for that type of head unit and I am not sure what model that is.
For starters have a look at this: https://www.jaguarforums.com/forum/x...others-101568/
#58
XJ x350
Buttcrackplumber
04-16-2019 06:57 AM
Maddashimports
11-11-2017 05:44 PM
worldrider
08-11-2015 07:31 AM
