How to remove -Part Load Breather Connector
Guest
Posts: n/a
I got a 2000 XJR and recently got P0171 and P0174 DTCs, I read some of the treads to correct this problem. Here is what I have done so far;
1. Removed and cleaned the MAFs with CRC MAF spray cleaner
2. Removed and cleaned the Air Intake tube
3. Cleaned the throttle plate and housing with STP Throttle cleaner
4. Removed and cleaned the Full Load Breather Hose ( notice there was some oil build up inside)
One last thing I read for me to do based on the recommend thread I read on this forum was to remove and clean the "PART LOAD BREATHER HOSE" and also clean the orifice hole, however my main problem was I am having a hard time removing the BREATHER HOSE CONNECTOR from the crankcase cover. Is the a special trick on how to the remove the plastic connector without destroying it? I tried prying it with a flat screw driver and plier to no avail.
Desperate- I am almost there!
Jaghead
Phoenix, AZ
Jaghead
Phoenix, AZ
Might get a better response if you put this in the proper forum. ie.. the Jaguar XJ8 & Jaguar XJR 1998-2003
https://www.jaguarforums.com/forum/f...splay.php?f=27
Any pictures or location details on these repairs? I have the same exact error
Jaghead
Phoenix, AZ
Jaghead
Phoenix, AZ
XJR Throttle Body, MAFS, and Part-Load Breather
I found this link to clean the air intake system. It works great. Step by step instructions.
http://www.maxperformancecars.com/dm...Clean_MAFS.pdf
edobernig (07-02-2012)
Jerry:
I recently purchased a 2000 XK8 from a Professor at BYU. He took extremely good care of car during his 9 years of ownership. However, when I had it inspected by the Jag dealership in SLC they noted that the Full Load Breather needed servicing. I am sort of a novice working on engines, so do you think I could perform this task? Or would it be better to have a professional in Denver do it?
Thanks,
Ed
Thanks,
Ed
Jerry Taylor (06-30-2012)
Full Load Breather
Ed, you can do this yourself. Follow the instruction (below link) as it pertains to the Full Load Breather Just be careful removing the breather hoses. Just squeeze and pry up gently with a slot screwdriver.
Good luck
Good luck
aholbro1
08-05-2021 05:02 AM
