HOW TO REMOVE THE REAR SEAT ON A 2008 xj8l JAGUAR?
Feel around the lower front edge for some plastic triangler shaped "fingers". If you find them, try to move them either left or right. They are latch releases (4 of them). If they won't move, put a little downward pressure on the seat at the same point as the latch. Once you have released all 4 latches, lift the front of the seat up to unhook the rear. Be mindful of any wiring for heated seats or whatever.
XK8+XJ8L (10-19-2020)
Same with abonano's suggestion. When you pull down on a strap and lever the top of the back seat out a bit put something down behind that part of the seat that will keep it from re catching a you move to the 2nd strap.
I don't know if I previously posted this youtube video I did. I just about broke my finger trying to get the seat out, but once I had it out and saw how the clips worked, it became very obvious/easy. So I videoed the clips. Hopefully this will help. If the link doesn't work, do a search on
2005 Jaguar XJ8L (X350) rear seat cushion release latches
FreeWifi (02-26-2022)
There's another rear seat thread where I made this reply... While the seat bottom was out, I marked a line on the carpet at the push-tabs with a sharpie. With the seat in place, the marks are not visible unless you're crawling on the floor looking for them, but you won't have to hunt around as much to find those tabs any more!
JimC64
03-02-2015 08:07 PM
Project Jaguar
07-22-2010 03:23 AM
