"How To Replace: Windshield Wipers 'O4 XJ VDP
This another helpful, "How To", to add to my other successful posts regarding oil changes and brake jobs.
This vintage Jaguar has very complex windshield wipers. The wiper blade assembly has the washer spray nozzle integrated into it, the drivers-side has an air-foil attached and they are two different lengths. Also you can not lift the arms very high when servicing them. Factory is the only option, since generic wiper blade replacements will not work.
The simple solution is to just replace the blades. They are manufactured by TRICO and sold at O'Reilly for about $15.00 total.
TRICO refill part numbers: 45-190 and 45-245 @ $6.99 each.
Link to O'Reilly Auto Parts: http://www.oreillyauto.com/site/c/se...04&make=Jaguar
They are two different lengths. The longer fits the drivers-side.
![](https://www.jaguarforums.com/forum/attachments/xj-xj6-xj8-xjr-x350-x358-28/70470-how-replace-windshield-wipers-o4-xj-vdp-edobernig-107535-albums-pedals-valve-stem-caps-4349-picture-two-different-sizes-required-22903.jpg?dateline=1390839819)
Replacement is simple. Locate the tip of the old blade where the stainless steel "Barb's" are visible. Carefully take a pliers and squeeze them together while pulling away. This should release the blade and it can be pulled out easily.
![](https://www.jaguarforums.com/forum/attachments/xj-xj6-xj8-xjr-x350-x358-28/70473-how-replace-windshield-wipers-o4-xj-vdp-3-edobernig-107535-albums-pedals-valve-stem-caps-4349-picture-stainless-steel-retaining-clips-22.jpg?dateline=1390839819)
Now on the new refill, there are (3) black plastic retainers that temporarily hold the stainless steel strips into the sides of the rubber blade prior to installation. These slide down and are discarded as you thread the new blade onto the wiper.
Easy low cost fix. Works great. Good luck.
![](https://www.jaguarforums.com/forum/attachments/xj-xj6-xj8-xjr-x350-x358-28/70469-how-replace-windshield-wipers-o4-xj-vdp-edobernig-107535-albums-pedals-valve-stem-caps-4349-picture-trico-refills-22902.jpg?dateline=1390839819)
The following 5 users liked this post by Bladevane:
Finzi Holst (05-20-2021),
LovellyJubblies (10-21-2014),
Rac-Jag (10-17-2014),
V8driver (06-26-2019),
vdpnyc (03-18-2022)
When I first got my 350, the wiper blades that were fitted were not great! So I actually took the Aqua Blades that were fitted to my Volvo S60 (the car the Jaguar was replacing) and slotted them into place.
They are slightly longer, but the washer nozzles simply unclipped from my original blades and clipped straight onto the ones from my old Volvo.
They are still on the car to this day, have seen me through a British winter with no issues and took about five minutes to swap. Oh and my car passed its MOT (annual road worthiness test) last week
![Icon Beerchug](https://www.jaguarforums.com/forum/images/smilies/icon_beerchug.gif)
![Stick Out Tongue](https://www.jaguarforums.com/forum/images/smilies/tongue.gif)
Thanks!
The following 2 users liked this post by scooternva:
Don B (06-11-2014),
Finzi Holst (05-25-2021)
Just for clarity's sake, the URL for O'Reilly is Home Page | O'Reilly Auto Parts. If you Google "oreilly", the first site that comes up is actually NAPA Auto Parts, and the 45-190/45-245 stock numbers either don't exist or point to completely different parts! ![Stick Out Tongue](https://www.jaguarforums.com/forum/images/smilies/tongue.gif)
Thanks!
Thanks!
The part numbers listed are the valid ZICO manufacturers part numbers visible in the first photo on the packaging, not the vendors UPC. I added a direct link to the O'Reilly Auto Part page showing the exact blades for future reference of Forum members. Finally beautiful weather has returned to Wisconsin. Have a great day.
I've been looking for replacement blades for my 04 XJ8. I printed edbernig's photo of the two blades together and took it to my local O'Reilly Auto Parts store. There were several versions of Trico blades on the display but not the one in the photo. And the self-service gizmo where you look up your own blades called for a RainX blade.
I took the photo to the counter and asked about them. They did indeed have them in stock. $6.29 per blade (same price for 19" and 24 1/2") and very easy to install. They work great.
Here's a hint: If you go into O'Reilly looking for them and don't see them publicly displayed, ask for them. The clerk told me that they keep them in the parts racks behind the counter because people were bad to steal blade refills more so than the complete wiper.
The following 2 users liked this post by bookman:
edobernig (11-27-2014),
BTW To get the wiper to park itself half way thru the cycle, turn the ignition switch to on but not all the way to start the engine and pull the wiper stalk towards you (like a single wipe) and it parks itself.
https://www.carcarekiosk.com/video/2...e_wiper_blades
The Car Care Kiosk website shows how to do lots of little things, like bulb replacement, wipers, change filters, etc.
The following 2 users liked this post by Dr John:
Brit57 (12-23-2016),
Exactly what I did...
Thanks edobernig, This was great.
Now auto parts store around the Psadena CA area stocks just the rubbers anymore. I called national chains and independents.
I was able to get the parts on eBay. I found the Trico 45-245. But I could not get the Trico 45-190. Instead I had to settle for a NAPA 60-1900.
I got both with free shipping for around US$20.
Thanks again.
Thanks again.
