I am chasing a coolant leak
Old 06-14-2022, 01:03 PM
mpasiuk's Avatar
Interesting post! Glad I stumbled across it.. I recently had a coolant leak from the radiator (found after I pressurized system to 10 psi). I replaced the radiator, all the hoses (around the radiator, but not underneath the intake), water pump, and expansion tank. No more leak.... or I thought. I notice that every 1500 miles of driving, I get the low coolant light. There are no leaks anywhere (that I know of), but I haven't really checked thoroughly.
I have a 2004 naturally aspirated and didn't realize that there were coolant hoses underneath the intake. I'm going to pressurize the system again and see if I can find anything. Car runs and cools perfectly, but obviously there is a leak somewhere.
and YES the hose clamps are the BEST. Made the job much easier. Good Luck with your project!
Old 06-14-2022, 01:10 PM
rsa760041's Avatar
+1. Finally gave up on channel lock pliers and a 10" needle nose pliers. Bought similar to what you have and jobs were at least 80% easier. Good to hear from you.
Old 06-14-2022, 01:21 PM
rsa760041's Avatar
Next step here would be 'try the dye'.
mpasiuk
24
03-14-2022 10:12 PM
David Dulson
06-04-2020 01:51 PM
Ken2839
10-03-2016 09:42 PM
Drak
12-11-2015 03:45 PM
sinatrakat
09-13-2010 04:20 AM
Quick Reply: I am chasing a coolant leak
