I am losing oil in between oil changes , is it normal ?
Old 07-08-2018, 05:18 PM
Partick the Cat's Avatar
Sorry , I misread your original post, I read it as 2.5 quarts in 8,000 miles. 1.5, that's even better. 1.5 qtsUS in 8,000 miles is over 5,000 miles per litre. On a 200,000 mile 8 cylinder (32 valves ?) engine that seems very good to me. I'd say you are worrying about nothing.
HOWEVER what does worry me is that you don't seem to top-up the oil level between oil changes. Certainly you shouldn't be letting it go down by by 1.5 qrts; that'll take the oil level below the minimum mark on the dipstick. On an engine of that age I'd be checking it every 1,000.
Old 07-09-2018, 10:27 AM
rf69's Avatar
Thank you for your advice, I’m learning a lot in here
Old 07-09-2018, 10:33 AM
rf69's Avatar
Originally Posted by Box
Actually Jaguar document VSB07/2004 specifies the type of oil to be utilized. Original fill and recommended spec was WSS-M2C913-B which is a semi-synthetic 5W-30. Jaguar's current recommendation for all vehicle lines, including recommended for the 4.2L is Castrol Full Synthetic Professional w/FST technology. (liquid titanium additive) Virtually everything that is out there today on the market is Type-III made from base oil stock, even Pennzoil, which is re-condensed from natural gas. Even Mobil is Type-III and not those synthetics that bring with them issues like PAO Type-IV or Ester based Type-V stock, so concerns with seals is rather misguided.
Thank you for the good information, I’m going to try
full synthetic next time, I’ve been using 5 W 30 Castrol High millleage for about 3 years
Old 07-09-2018, 10:49 AM
rf69's Avatar
With a high-miles engine as yours is, the oil will be disappearing down the inlet valve guides. There is serious vacuum on the inlet side, plus a lot of oil sloshing around to keep the cams lubricated, so seals are placed on the inlet valve guides to stop oil loss. The seals have to allow a certain amount through to lubricate the guides but not too much. I had a similar problem with my Mazda Xedos 9, but never fixed the problem as I part-exed it for a Rover 75. The old Jaguar XK engines really drank oil until seals were put on the inlet guides. About a point of oil every 200-250 miles !!
So, replace the seals and the oil loss will diminish. Not a simple job, though, you have to lift the heads
Thank you for the valuable information,
my next project would be replacing the lower Control Arms bushings , there is a play when I go in reverse using my breaks, My mechanic is charging me
$500 in parts and labor that also includes alignment
I wish I can do it myself but I don’t have the right tools.
it sounds funny because I replaced the air shocks myself with Arnotts about a year ago and I’m having second thoughts about replacing the lower control arms bushings or upper , I don’t really remember what my mechanic told me but he said that there’s a play and my steering wheel shakes a little bit while driving under 50 miles if I go higher in speed it disappear
XavierJ
12-31-2021 01:11 AM
CleverName
01-06-2012 06:49 AM
Blue Lion
46
09-06-2011 01:02 PM
mckellyb
04-20-2011 10:31 AM
Quick Reply: I am losing oil in between oil changes , is it normal ?
