I just bought a 2004 Jaguar XJ8 with sport package
"Everything was perfect except for:
The front driver seat and center console were very dirty.
There are lots of fine scratches in the paint.
It was not the Sport package as the owner indicated ."
Annamiata the so called "Sport" was not a separate model but a car equipped with the Sport airbag susp0ension instead of the ones labeled comfort. If you can get someone with a scanner that can read the Jaguar proprietary codes they can input the serial number, run the diagnostics and give you a look at the way your car is equipped. If it as the Sport bags it will show-up
After a full day of exterior detail, I got rid of all the fine scratches using a buffer machine, foam pad, and 3M no silicon polish compound. I buffed all exterior surfaces and now it has a show room condition appearance. I left the remaining three deep scratches alone. I will fill them with clear resin, multiples stage sand, and then buffing.
When the new design (represented by your 2004) came out, there was a lot of controversy because it was not as low-slung as the older version (2 inches taller I think - to give more headroom). "Low slung" implies sportiness. What are your thoughts on the driving comparison between the two? Is the older version clearly a more sporty feel or are they roughly equivalent, or is the newer one more sporty?
When I parked both cars next to each other, I like the look on both.I like the detail curvatures on the 1997. The 1997 does look sportier due to its low profile. The 2004 is more modern/smooth design. The 2004 used the cab forward and taller design and created more interior room. Parked the 1997 next to 2004 and I can see the front portion/bonnet/hood of the 1997 appears too long. I bought the 2004 for the lady of the house and she noticed that she can not see forward as well as the 1997. She also immediately noticed the blind spots from the two side pillars from the 2004.
The 2004 XJ8's suspension system is still too soft for my taste. It's not fair comparison since I drive a modified Mazda MX-5 with coil over and supercharger on the weekends. I wish Jaguar would design the Active air suspension 2004 and forward with selectable ride comfort.
The 1997 XJ6 suspension is softer than the 2004. It bounces (boat like) over pot holes.
There no questions that the X350 is a better car and there no questions that the X305 is the most reliable Jaguar.
FRGIII2014 (12-09-2014)
FRGIII2014 (12-15-2014)
#28
FS[MidWest]: FS: 1999 VDP *lots of pics* in mid-Missouri
souldoubt
08-25-2015 08:15 PM
