I need help with a DIY Tune up on 2005 XJ8L
Greetings Everyone,
I am looking to do a DIY tune on my cat. I need help from experts on whether or not I should and if so, I need help on what to get and what to do.
My Jag is a 2005 XJ8L and has 176k on the dash. What other info do I need to provide?
Received 13,103 Likes
Hi mrkaine,
If my math is correct, it has been about 136K miles since the last service, so you're long overdue.
Off the top of my head, I would recommend:
Oil & filter
Air filter
Clean the MAFS wire & electrical connector with zero-residue cleaner spray
Cabin microfilter
Fuel filter
Spark plugs
There are no spark plug wires because the system is coil-on-plug
Inspect the air intake pipes, breather hoses and vacuum lines for deterioration or leaks
Inspect coolant hoses and replace as necessary
Inspect the drive belt(s) and replace as necessary
Consider replacing the coolant thermostat & flushing the cooling system
Flush transmission fluid & install new pan/filter and electrical connector sleeve
Flush brake fluid
Check condition of brake pads and rotors
Clean all ground studs and the ground strap in the engine bay
Clean all ground studs and battery terminals in the trunk
Clean the ground studs in the passenger compartment as you can
Check front wheel bearings/hubs with brake calipers & discs removed
Inspect suspension for deteriorated bushings, ball joints & tie rod ends
Inspect engine mounts
Inspect for fluid leaks
Rotate the tires
Clean the drain under the microcabin filter/ECM
Clean the sunroof drains
Windshield wiper inserts
Check all exterior lighting for proper operation - including side marker lamps & license plate lamps
Check the Air Suspension Relay, R1 in the Front Power Distribution Fusebox, for signs of overheating and replace if necessary
Consider replacing the piston ring seal in the air suspension compressor
Consider replacing the CR2032 battery in the key/remote
I'm sure I've forgotten something but others will chime in.
Cheers,
Don
Oil & filter
Air filter
Cabin microfilter
Fuel filter
Spark plugs
Flush brake fluid
Rotate the tires
Cheers,
Don
Hi mrkaine,
Oil & filter
Air filter
Cabin microfilter
Fuel filter
Spark plugs
Flush brake fluid
Rotate the tires
Cheers,
Don
Oil & filter
Air filter
Cabin microfilter
Fuel filter
Spark plugs
Flush brake fluid
Rotate the tires
Cheers,
Don
Received 2,263 Likes
Just to back-up what Don B said. The Jaguar X350 cars should be serviced at 10k mile intervals or every year whichever comes first, so your car is 4 services behind, and really asking for trouble.
I presume you haven't had the car all that long and it was the previous owner who thought servicing was a waste of time and money.
Hi mrkaine,
Oil & filter
Air filter
Cabin microfilter
Fuel filter
Spark plugs
Flush brake fluid
Rotate the tires
Cheers,
Don
Oil & filter
Air filter
Cabin microfilter
Fuel filter
Spark plugs
Flush brake fluid
Rotate the tires
Cheers,
Don
![Icon Frown](https://www.jaguarforums.com/forum/images/smilies/icon_frown.gif)
Cheers,
Don
AD2014 (11-25-2016)
