I need a replacement trunk liner panel for 05 Super V8
Old 03-18-2019, 10:33 AM
JCalhoun's Avatar
Default I need a replacement trunk liner panel for 05 Super V8
Something happened to the passenger side trunk liner panel in my Super V8's previous life. I'm thinking battery acid spilled because there is a 6 inch square section of the liner that has all the fabric covering eaten away just above the battery. The car is so nice otherwise I would love to replace the panel but every time I find an XJ8 at a recycling yard they have filled the trunk with "loose parts" and ruined the liner.
1. Any good references for Jag friendly recycling yards? (Particularly in the northeast)
2. Are the liners the same color and size for all XJ8's ? (did they change for long wheelbase or by year?)
3. Should I forget about it and focus on things that really matter like bleeding the brakes and cleaning the grounds?
Jeff
Old 03-19-2019, 07:51 AM
Wingrider's Avatar
Red face
All good questions Jeff, sorry i have no good answers.
My 07's, were not available when i called the dealer's parts dept either.
Seems about anything mechanical can be sourced from the salvage yards.
As well as body panels, cabin i​​​​​Interior parts.
Not much trunk liner's, or plastic under body panels.
Not needed to run, not seen when driving, so who cares??????????
Seems to be the general outlook.
Focus on catching up, on the cars neglected maintenance, while you look for the liner.
Old 03-19-2019, 10:08 AM
JCalhoun's Avatar
Wingrider you are wise...
Old 03-19-2019, 06:52 PM
staggerlee51's Avatar
Go to SNG Barrett site. When you select Parts, it takes you to screen where you select model, then drop downs to zero in. If you have difficulty maneuvering the site, give them a call. Frank always answers when I call.
Old 03-19-2019, 08:15 PM
I have had no luck retrieving usable parts from junk yards. But, you might find a fresh, new boot liner here. Go to SNG Barratt’s site. Select Parts and follow menus for different models and parts categories. If difficulty maneuvering side, call. I have spoken to Frank re a few items.
Old 03-20-2019, 06:53 AM
310jag's Avatar
You might be surprised what a good degreaser and steam cleaning will do for a badly stained interior panel. A used one will be far cheaper than a new one from anywhere. Or you could always keep an eye on ebay.
ndy.boyd
09-02-2016 06:00 PM
YycXJS
12-16-2013 07:46 AM
wrd0225
10-11-2013 08:28 PM
Grip
05-06-2009 10:00 PM
Quick Reply: I need a replacement trunk liner panel for 05 Super V8
