I think I finally found my clunk and vibration issue
Lower curved arm bushings seem to be shot. Question is do these have any adjustability for alignment? I know them being worn can cause tire wear issues of course, but I mean do the installation of them bolt into a specific spot, or do they have some adjustability that would require and alignment to place properly?
Did mine a little while ago, replaced them as a pair. Yes they have concentric bolts so I would mark where the old ones were, I also got a full alignment done afterwards. Unfortunately for me I still have a slight wheel wobble! But the steering feels better and the new arms have a slightly re-designed large bush that looks stronger.
And problem solved. I was wrong again. Tire wear is perfect, but I got the front end off the ground and removed the wheels. Jerked the steering wheel back and forth and was able to recreate the clunk. The steering rack bolts were loose! No wonder it kept getting progressively worse! I'm going to go look up the torque spec on these bolts to make sure this doesn't happen again. What a scary find!
JimC64 (07-29-2016)
Let us know
My car suffers from a little steering knock on rough pavement. Tightening the lug nuts helped a lot.
When you find that spec let us know.
I still haven't found the steering bolt torque spec, but snugging the bolts clearly fixed my problem after a drive. The clunk is gone, the steering is more direct and solid feeling. The wheel shake is gone now too.
It definitely means my ears are still in tune on vehicle noises. It sure sounded too metal on metal to me to be a bushing, especially since the main thing that people have said is that you can usually wiggle the curved arm by hand if the bushing is worn and I couldn't find any slop in it. Not only that in order to get that much bushing slop to be metal on metal I'd have severe tire wear issues. Actually both lower arms both curved and straight on both sides looked way to clean to be original and the tie rods were super clean and solid. The upper arms looked pretty dingy and are probably original but that doesn't mean anything when it comes to the bushings themselves. I don't really suspect any of them to be on their way out right now. The car drives entirely too solid for that right now. It feels like a new car again minus the slightly different feel of coil springs instead of air springs.
Thanks Torrid, as you know I've been chasing a similar issue with mine. I'm having mine looked at around Wed / Thurs next week and will be asking them to check this for me too
Best
When I had to drop the rack to replace the left engine mount the rack bolt torque was listed at 100 Nm or 74 Ft Lbs and the steering universal pinch bolt was 25 Ft Lbs.
al_roethlisberger
04-09-2016 04:50 AM
clivedavies
04-07-2016 11:21 PM
