I want to change my thermostat housing ?
I want to change my thermostat housing from plastic to metal is there any good step by step procedure with pictures ? , I want flush the system should I power flush the system ? or is there a good way with a garden hose and acomplish the same thing ?
![](https://cimg0.ibsrv.net/gimg/www.jaguarforums.com-vbulletin/1600x1195/img_0018_483905f2af126d84c57695cc3a34b6e5570b4a43.jpeg)
The thermostat housing is metal??
From my experience, to change stat, pasted from my car diary;
"You remove the intake duct, stuff a bunch of towels underneath the thermostat housing and around anywhere that coolant may leak. two T30 bolts on the top of the housing, and one major PITA bolt underneath that I just removed using the wrench as leverage turn by turn slowly but surely.*
Half a QT of fluid spilled out when I opened the housing, be quick. Note the thermostat orientation when you replace it. Mine looked perfect but was sure enough stuck open. Easy job. Replace coolant with Dexcool*ORANGE*from your local Autozone, REMOVE TOWELS.
Cleared codes, issues resolved."
tailfin joe (03-27-2015)
The N/A engines have a plastic thermostat housing, the S/C cars are metal.
This problem also afflicts the S-Type (same engine) and there have been discussions about it in the S-Type section. Example https://www.jaguarforums.com/forum/s...uestion-61609/
The earlier 4.0L engines do have a conversion kit to change from plastic to metal, not sure about the 4.2L though...
Have a search in the S-Type section as there are a lot more 4.2 N/A S-Types out there, maybe someone has the answer already...
EDIT
No it seems there is no metal update for the 4.2 https://www.jaguarforums.com/forum/x...3-tips-114486/
EDIT
I dont know of anyone that has but its best to check in the Stype forum as well
I cant see why you could not change them over but you would need some new hoses ect
PS you would need the housing for the top of the block as well as the water rail (thermostat housing)
Looking at the JEPC it looks like it will fit but cant be sure
34by151
34by151
This is what we use on XK8s; I think the engine is the same, right?
JA-AJ8-2697 - Thermostat Assy Most Non-Supercharged 4.2 V-8
Check the XK8 DIY thread for some installation tips and references.
