idle dropping at a stop
Minor annoyance, but lately as I come to a stop the idle dips down, then a second later picks up. Will also do this with change in engine load (e.g. fans kicking on). It acts like it has a dirty idle air control, but of course this engine has no IAC. I've cleaned the throttle body and there's no sticking issues there. Only seems to do it when the engine is hot. Anyone run into this? No issues otherwise. No odd fuel trims.
Thanks,
-Michael
Thanks,
-Michael
My apologies....I had an erratic idle when I forgot to reset my throttle after a battery disconnection which went away when I pressed the pedal through the détente to the floor a few times with the ignition on but the engine not started? My situation must have been different or just a coincidence...
Thanks for all the replies.
Ayavner, that jogged my memory and I remember the same thing happened to me as well--but I replaced the MAF sensor with a new OEM 10k miles ago. Hopefully this is not bad again or some intermittent electrical issue.
Front O2 sensor were recently replaced with OE. I left the rears for what it was worth. I did check on the fuel trims again, and sitting there at idle they just bounce around 0% with the most excursion to +/- 3%.
My throttle body is going on 124k miles and 13 years, maybe it's just getting worn out enough to cause this minor issue.
Alaskamike
12-06-2012 07:11 AM
hawaiianjag
11-30-2012 06:24 PM
