IDS/SDD: is it possible to clear codes while engine is running?
I know Jaguar requests to run IDS/SDD while key is on Ignition II but engine non running, and with a stabilised 60 Amps 13.6 Volt power supply connected to the battery.
But situations may arise when DTC's are logged hindering operation of the car, and when no external power supply is available to safely operate IDS/SDD with a VCM or a Mongoose.
If e.g. an ASF is triggered only because the compressor could not raise the car after two attemps in a very cold climate, and if a logged DTC then blocks any further operation of the compressor, the only way out will be calling the assistance...
While if the engine can be operated for some time and heat the engine bay (in particular the heads of the struts), there is a chance to succeed in raising the car later on if the code is cleared and the compressor can be reactivated.
So my question in the title, because the alternator itself can deliver a few tens of Amps at 14 V, that may allow to safely plug a current consuming VCM in the OBDII, acquire data and possibly clear codes.
Thank you all,
I agree that DTC's related to ECM would not be cleared while running the engine and that ongoing defaults would trigger DTC's back.
But it is good to know that DTC's could be managed this way, especially if the car is recovered with an ASF and a weak battery after being parked a couple of weeks during a harsh winter.
