Ignition barrel jammed
We are talking about 1mm long. Can the cylinder be disconnected and flushed out upside down with contact spray??? Tried all day with a. Thin piece of copper wire to no avail., p.s. Think this might have something to do with battery drain as well as the steering lcock was not clicking off and on before but now after some graphite grease the steering lock makes the usual clunk when you insert and remove the key. Can get the key in easy enough but stops shy and does not rotate.
his196
09-25-2014 02:52 PM
