ignition coil 2004 jaguar xj8
in simple terms, the coil requires a specific voltage/amps to operate efficiently, adding lighting to the same circuit would draw a significant amount of power from that circuit. You might start to receive high voltage/amp error codes as the ecm does not know there are lights on the same circuit. Much safer to connect to the lighting circuit. I would first check if that modification is legal, just because others are doing it don't make it legal....
milhunkcj (04-21-2015)
Received 12,952 Likes
Hi milhunkcj,
Welcome to the Jaguar Forums!
I agree with reyesl. You do not want to add additional load to your engine ignition system.
You can download the 2004 X350 Electrical Guide at the link below to help you find the power source(s) you will need:
http://www.jagrepair.com/images/Elec...al%20Guide.pdf
Because the X350's electrical systems are so complex and sensitive to variations in resistance, voltage and current, it might be safest to power your running lights directly from the battery. There are a few places in the engine bay where you can access battery power. Then use an isolation relay to control the running lamps via an ignition-switched circuit, and add an inline fuse of appropriate amperage to protect everything from a potentially disastrous short.
Hopefully others will chime in with additional thoughts.
Also, I note that you've made 10 posts to the forum but have not yet visited the https://www.jaguarforums.com/forum/n...-intro-must-5/ to post an introduction. Please post an intro so we can learn something about you and your Jaguar and give you a proper welcome.
Cheers,
Don
X_Type_South_Africa
12-09-2015 05:37 PM
Will P
08-27-2015 06:52 PM
FS[MidWest]: FS: 1999 VDP *lots of pics* in mid-Missouri
souldoubt
08-25-2015 08:15 PM
