Ignition switch
Received 13,158 Likes
You're making progress. It definitely could be a relay. Off the top of my head there's a rear ignition relay in the Rear Power Distribution Fuse Box in the trunk, and a slave ignition relay in the Front Power Distribution Fuse Box. There are a couple of Switched System Power Relays in the Passenger Junction Fuse Box. Check the schematics in the Electrical Guide, which you can download here:
2004 XJ X350 Electrical Guide
I can't recall the year and model of your Jag, but if it's not an '04 just check at jagrepair.com for the guide for your year. It's a great idea to add your car's year, model and engine info to your signature line so others don't have to ask in order to give you accurate responses.
I'm not sure which relay(s) are involved in Auxiliary functions, but I would suggest you start on the schematics for the components that are staying on, and work your way upstream in their circuits until you find a common relay or other component.
Cheers,
Don
EssOess (03-03-2017)
Hi Bill,
Cheers,
Don
Cheers,
Don
1. The car will not crank: starter not engaging. Turns out I'll need to find someone to program the new key to the car. Bummer. I didn't think about that... dealership only?
2. I still have the problem with the radio, etc. remaining on when the key is removed from the ignition. I'll sort that once I get it to start.
This is my 2004 XJR (It's in the signature)
Thanks Bill.
I'm glad you are slightly ahead of me, so don't fall into the same trap. Too bad for you though.
I guess it makes sense that if the ignition was on due to bad switch, that all functions (wipers etc) would be on too. But in your case, and mine, only certain items remain powered up. This points to the relays as Don says.
My situation is that the instrument pack and light switch remain powered. I'm looking at the Elec Guide (pg 64 I think), and note that both of these have the same power source. I'll let you know if a find something,
Rob
Rob
