injector replacement 2004 XJR - supercharger removal?
My 2004 Xjr has a bad injector (cylinder 7 i believe), My mechanic says he has to remove the supercharger to do this, so it's $2100 just for the one. He's a Jag guy but I am still it bit skeptical. It's $3500 for the set - the car, which is great otherwise has 119k on it. Who is knowledgable? Thanks in advance. David Q
by memory - scanner's in the car
at diff shop for second opinion
misfire 7
catalyst fail/damage bank a
random misfire
cylinder 7 misfire
injector circuit 7
i cleaned maf sensor and replaced coil and plug in seven
no change
idles a bit roough - cuts out at 3k rpm
sometimes engine light, sometimes flash and sometime no engine warning light
misfire 7
random misfire
cylinder 7 misfire
injector circuit 7
no change
Received 2,192 Likes
injector and or coil circuit failure codes are almost ALWAYS electrical failure of the component. you can use a scope to confirm the driver in the ecu is not the problem but past that you cant check the wiring to the injector unless, yeah, you pull the sc. If it where me I would at least replace that one and have the rest cleaned sonicly by a company like www.injectorrx.com.
youll need all new gaskets, a correctly sized o ring for the brake booster vacuum line in the throttle body elbow that always leak vacuum and cause p0171, p0174, plus a couple vacuum plastic lines and the heater hose under the sc that leaks and will require the sc removal later if you don't do it now. Now would be a nice time to put a smller sc pulley on too for 3psi more boost and boost that comes in sooner since the snout has to be machined to fit it.
you asked
you asked
Dustin Moorman
01-10-2023 08:42 PM
TrevLevin04XKR
10-09-2017 05:02 AM
hawaiianjag
05-29-2016 02:19 PM
