Inner door rubber
I had the same problem. They are discontinued. I was able to source one from a Salvage yard, that I pulled off by myself. I also know that the driver and passenger side are that same. If you find one at a salvage yard go to the passenger side. it is more possible that it will be in good condition. very easy to remove and install. You can do it with your hands. No tools needed. So I check my local salvage yards once a week to see if a Jag from 2004 to 2009 come in. Hope this helps
SymbolicMike (Today)
