Input selection for Sirrus radio
It's tuned to a certain FM frequency as there's a FM Modulator built-in to the Sirius unit. In the Sirius display, you should be able to scroll through it's menu and find something that says "Frequency" or something like that. In there, you can turn the Modulator on or off, and you can set the frequency to your liking. Then tune your FM radio to that frequency and you should be good.
Will check tonight.
BTW, thanks for the help with using. I kept looking for a button to select AUX input. Forgot about the FM modulators. Never would have figured it out.
