Installing Arnott Coilovers X350
very well articulated. I have one comment on Step 5.
"5. Unplug all four ASM plugs and tie out of way."
you may consider applying liquid insulator or somehow sealing the four connectors. Moisture will find it's way into the exposed terminals and with the CAN bus exposed
on one of those connectors it's like inviting gremlins into a highly stable system.
Bob
Bob
Received 2,192 Likes
Bob
Bob
Rear almost finished. Will finish tomorrow. Just for grins, I took it for a ride with coils in front and air in rear. Rode like the original as well as I can tell. No body roll. The left front is a few MMs higher than the right but both are in specs. Hopefully they will even out.
One thing that I have noticed is that the dust boots on all the ball joints, tie rod end, bushings are made of a kind of surgical rubber that is falling apart. The joints themselves are OK. Brutal, can you replace just the boots? They are held on by spring rings. I took most of them off as they are ugly and serving no purpose.
NO FAULTS!!!
![Icon Dance Cpatch](https://www.jaguarforums.com/forum/images/smilies/icon_dance-cpatch.gif)
![Icon Dance Twist](https://www.jaguarforums.com/forum/images/smilies/icon_dance-twist.gif)
![Icon Eddie](https://www.jaguarforums.com/forum/images/smilies/icon_eddie.gif)
NO FAULTS!!!
rear almost finished. Will finish tomorrow. Just for grins, i took it for a ride with coils in front and air in rear. Rode like the original as well as i can tell. No body roll. The left front is a few mms higher than the right but both are in specs. Hopefully they will even out.
One thing that i have noticed is that the dust boots on all the ball joints, tie rod end, bushings are made of a kind of surgical rubber that is falling apart. The joints themselves are ok. Brutal, can you replace just the boots? They are held on by spring rings. I took most of them off as they are ugly and serving no purpose.
no faults!!!d
no faults!!!d
I've seen fretting jump terminals on other applications and whether it's legged like you say, I've always considered any BUS circuit vulnerable when exposed. All it takes is some car wash jockey leaving the back window cracked and the unthinkable happens... regardless, moisture finds it's way to dry exposed conductors..
Eddie, take it over a tall speed bump at the park and seat them in. Measuring wheel well height with three hundred and fifty pounds in trunk sure would be interesting. I did that using five 5 gallon buckets of rocks on a Cadillac with air rears..
Bob
Bob
Bob
Bob
#30
350?? Geez Bob I have a truck for that. I will put a couple of hundred in it. By far the most it will see.
#32
#33
#34
#35
#36
#40
I THINK HE PULLED IT FROM THE INSTALL MANULA IF YOU SEE THE PIC HE ADDED. BUT I THINK THEYRE JUST REFERING TO THE LOWER SPRING MOUNT THAT CAN HAVE THE COIL DISPLACED THE ITS SEAT, AND OR THE STEEL MOUNT CAN BE COCKED ON THE SHOCK BODY LIP AND NOT SET CORRECTLY. BUT..... IF YOU WHERE TO HAVE A SET OF RADFLO OR IKON THREADED SHOCK BODIES THAT ARE ADJUSTABLE WITH A SPANNER WRENCH![Icon Denk](https://www.jaguarforums.com/forum/images/smilies/icon_denk.gif)
RADFLO SHOCKS - Bing Images
