Instrument cluster
Trevor Petit (07-16-2020)
You can't swap them without programming using the SDD. The odometer reading must be transferred to the new IP.
BUT I have seen people take the replacement cluster apart then de-solder some of the components and replace them on the original cluster.
Pretty in depth and you must know which parts to remove and transfer over. Looked too complicated for me.
Maybe take yours apart and see if you think you can do it?
I even saw a guy who figured out which chips contained what data so he moved the chip containing the original odometer reading and everything worked OK.
Since you have the older version of the XJ it still has the old analog gauges I bet you could swap the speedometer into your original. Maybe the temperature gauge too?
You'll most likely find that its just the needles have stopped working (or are working erratically) because the stepper motor gears have worn away or broken. You can de-solder the stepper motors from the old unit and replace them with new stepper motors. Doing this will mean that you can use your old cluster without the need for reprogramming.
car5car
10-16-2023 11:42 AM
LoopbackZero
08-29-2014 12:58 AM
