Intake manifold gasket replacement
In the process of the intake manifold gasket replacement, the manual says remove the cowl vent screen, held on with retaining clips. Well the clips are out,screen slides left and right, wipers are off, but can not get the screen to come out
The issue seems to be it's hampered by the windshield, and won't come out far enough to remove it
What tool is used to get it started?
Has to be something simple, but seem to be missing it somehow
![Mad](https://www.jaguarforums.com/forum/images/smilies/mad.gif)
![Icon Deadhorse](https://www.jaguarforums.com/forum/images/smilies/icon_deadhorse.gif)
![Icon Question](https://www.jaguarforums.com/forum/images/smilies/icon_question.gif)
![Icon Sad](https://www.jaguarforums.com/forum/images/smilies/icon_sad.gif)
Sort of sounds like you were there,
have not got it free yet.
Decided that when a friend of mine shows up, will try taking the air struts loose at the top, tilt the hood back. Then tilt the piece up more before pulling to see if that gives me the needed space.
![Icon No](https://www.jaguarforums.com/forum/images/smilies/icon_no.gif)
![Icon Teeth](https://www.jaguarforums.com/forum/images/smilies/icon_teeth.gif)
Looking at the part, it has cut out's to miss the hinges, so it can be lifted a little higher. The fly in the ointment is, the struts that hold the hood up, are in the way. Remembering my first experience with the British way of doing things with my Triumph motorcycle. Hard for me to think like a limey, blimey they have a weird way of doing things. Almost all to keep you away from fixing it yourself. Little things to trip you up, maybe you break something, that take's supposed take a week to get here, but that can become a month
The cover locates into a channel at the base of the screen with no mechanical fixing, the previous advice of 'tearing it out' is a good way of putting it.
Start from one side and pull it up over if this is the first time it's been off it will be well stuck but it will come off. It is not necessary to remove the strutts or bonnet to get it out as once freed off it is flexible enough to get past them.
My biggest problem was getting the windscreen wipers off!
Good luck with it.
Good luck with it.
Has to be something simple, but seem to be missing it somehow![Icon Sad](https://www.jaguarforums.com/forum/images/smilies/icon_sad.gif)
Manual is on line download, a disk costs more, to burn, & send, not my choice of a shop manual at all. But a look at the sheer number of pages (6,384)
explains it all!!!Factory Service Manual, 2004-2009,XJ, XK8,XJR DISEL SERVICE REPAIR FSMMANUAL. $14.95 Plus the price of a disk if you want one. Pretty much has it in there somewhere,
whatever your looking for. Takes a bit of time, but you copy the needed pages, & don't worry about getting them dirty. As a new one is easily had.
![Icon Bricks](https://www.jaguarforums.com/forum/images/smilies/icon_bricks.gif)
![Icon Wub](https://www.jaguarforums.com/forum/images/smilies/icon_wub.gif)
![Icon Steer](https://www.jaguarforums.com/forum/images/smilies/icon_steer.gif)
Well finally got the intake manifold gasket replaced, taking my time, everything seemed to be going pretty well. then found the two E G R valve bolts on the bottom, were rounded off. so took the two horizontal bolts out instead to free it from the throttle body.From the looks of things, this job had been attempted B4, the gaskets were really kinda cheap looking, with no rubber around their openings, were not nearly as nice as the Lincoln ones. The two clamps on the E G R valve coolant hoses, were of a non reusable variety, as well as one manifold bolt did not have the non removable washer, that were on all the others. With the job completed, or so i thought, car runs very rough, throws codes PO300-PO308, with 0316 as well. Misfire on all 1 through 8 cylinders, with a 0316 topper, which says TOO many misfires, put 7, of the 8 new spark plugs in with no help, will do #8 some other day. Any ideas on what went wrong, and or what to do would be appreciated, as i have no idea what went to do
The code reader suggest an open E G R valve, what that means, or how to close it, i have no clue.
![Red face](https://www.jaguarforums.com/forum/images/icons/icon11.gif)
Well today called the Jag dealer, & was told the solution to my issue was 8 new coils, reminds me why i stay away from them!!! Does the E G R come apart to clean??? Mine seems not to want to pull up & out after removing the top bolts, don't want to break it just fix it. Question is did i do something WRONG??? Hate to think about redoing the whole job,but if i buggered things up somehow,i have no other choice.
Or could this be a two piece manifold, & another set of gaskets between the plastic, & metal, that i missed WTF???
Want to get this fixed B4 it drives me totally over the edge
![Icon Badrazz](https://www.jaguarforums.com/forum/images/smilies/icon_badrazz.gif)
I had a similar problem on my '04 VDP. wouldn't pass smog in CA. Had to replace the intake manifold gasket, but it needed the unavailable gaskets between the two part manifold. Found a seller on ebay that probably had them made aftermarket. Not cheap, but they did the trick, and car ran as good as new afterward.
Got a Jaguar Jones wrote;
What was his deal, price, where, & how to get them?
__________
__________
After thought;
Wonder if the plastic manifolds bad reputation for warping, & or cracking is mainly the result of people over tightening the bolts.
Not knowing any better, thinking that they are not near tight enough.
Not realising that plastic uses WAY less torque on bolts to get a good seal, than metal.
![Icon Flamethrow](https://www.jaguarforums.com/forum/images/smilies/icon_flamethrow.gif)
