Intercooler Pump wiring diagram?
During a recent radiator replacement on my 2005 XJR, I found that the two wires that lead to my intercooler pump have been pulled from the plug. I suspect that some slack had developed and the wires caught on something.
The wires from the pump that lead up to the male/female plug are intact and still attached to the pump. These wires are red & black and white & black. The plug still has both pieces snapped together. There are two wires that appear to have been pulled from the back side of the plug; one is solid white and the other is solid black. Can anyone tell me if the white wire should be hooked up to the black & white pump wire, or should it go to the red & black pump wire?
The next step will be to source a replacement air mass meter hose (the plastic accordion hose) since a recent lean code reared its ugly head and my mechanic suspects that hose, or possibly a throttle body gasket, are causing the code.
Thanks!
Thanks!
Received 12,932 Likes
Hi Portfoliolio,
You can download the 2005 Electrical Guide here:
http://www.jagrepair.com/images/Elec...al%20Guide.pdf
If you can post a photo of the wires and connectors, I'll be happy to compare the same connector on '04 XJR to see if I can help you match up the wires.
https://www.jaguarforums.com/forum/x...uctions-48194/
If you do need to order new parts, check with forum sponsors SNG Barratt, Jagbits and Welsh Enterprises, who offer discounts to forum members, and also check with my long-time suppliers Coventry West (coventrywest.com) and jaguarmerriamparts.com, the Jaguar dealer in Merriam, Kansas who sells OE Jaguar parts at discount prices.
Cheers,
Don
AD2014 (02-16-2015)
Received 9,006 Likes
That PDF is an invaluable guide. Thank You! On page 66/67 it shows the intercooler pump and labels the wires as "B (Black)" and "NG (Brown & Green)". This is connector CP2. Detail of the harness end of things is shown on page 51 and the connector is labelled 'CP1' with the same 'B' & 'NG' colored wires. The problem is that none of the actual wires are Brown & Green. They are solid black and solid white from the clip or plug back into the harness, and black & red and black & white from the clip (plug) forward into the pump itself. To my knowledge, this is the original pump. I'll attempt to post a pick of what I'm working with, but the weather isn't cooperating with that today.
As far as the smoke test, the mechanic ran one but did not say that it confirmed his suspicions. He stood by his "those codes are usually caused by the air mass meter hose and throttle body gaskets". He reset the check engine light and it has not come back on... although he says it probably will return soon at idle. This light came on after the filter box and the rest of the air intake was removed and then re-installed during a new radiator installation. It did not go away after five cycles of the engine running from parked to normal running temp, and then back to full cool down. I suspect that the wires could have been pulled from the intercooler clip when the radiator was removed.
Cheers,
Don
Guy-Pierre Boucher
09-16-2015 05:55 PM
Daniel Howden
09-13-2015 02:28 PM
