Interior lighting issue (Video inside)
Hey there,
Just picked up my 06 xj8 today and everything was great (except for the unnoticed crack in the tail light). However, on the drive home I had an issue with the floor lights flickering. Not sure how the interior lighting works in this car yet so that's why I am asking before I try to better asses the issue myself.
Here's a vid to show the isssue:
Also I didn't know if the floor was supposed to have some sort of foot sensor? Or if my car is just having a little gremlin
You'll lose any memory settings, but a hard reset involves removing the ground cable from the battery's negative terminal touching it to the positive terminal ...holding it there for a few seconds, then reconnecting it to the negative once again. It discharges all stored settings and resets most computer modules within the car.
Haha, my xj is being a bit fiesty!
The windows should be easy to fix.
Push and hold down the driver's window button until it gets to the bottom. Then continue holding for about 3 seconds longer. Raise the window and when it gets to the closed position continue holding the button up for an additional 3 seconds. Repeat for all of the other windows. Save you from searching out the thread on reprogramming the windows.
darkman (04-12-2013)
BrentGardner
28
04-26-2024 04:08 AM
