Intermittent amplifier problem
Hi All. I am the new one to the forum so just getting to know my way around. I love my Jaguar Sovereign 2006. It behaving wonderfully and a pleasure to drive, but the stereo/Bluetooth cuts out over bumps usually. I just wondered if there were any words of advice about where to start looking. Loose contact between amplifier in the boot? Usually it will come back on either by another bump in the road, but oddly for sure if I stop and turn the ignition switch off completely and then back on again (hence my slight skepticism if its a loose connection).
I did try to post this before but can't find it so maybe somewhere else this appears and my apologies if my lack of forum knowledge has meant I have already lost my own post!
Regards
Rauly
Regards
Rauly
Hi Woodford Jag,
Thanks for the quick response. The multi disc changer had been bypassed and a apple music connection installed in the glove box, so when you select multi CD its actually the iplayer it connects to. The multi CD is still in the back (next to the amp I think).
If I follow I need to open up the cover over the amp in the back and check the connections are secure?
Regards
Rauly
Regards
Rauly
