Intermittent cruise not available message
@Paula
Your work around proves you have a battery problem. If you lessen the load by switching lights and a/c off at cranking, the cruise gets enough juice and doesn't give the error. Given that your battery is failing, I guarantee we soon see another thread with some other "weird" electrical issue, to which you will get the same reply, ie change the battery. The battery for my Super V8 was LESS EXPENSIVE than the battery in my wife's Integra. Why wait for the inevitable to happen?
@Brake boost
Not sure from your post if you have exactly the same issue? ie you only get the error upon first start? Or you never get cruise ever?
@Brake boost
XJL (10-13-2014)
I took the lights off auto for starting and keep the battery on the battery conditioner when I left the car for extended periods. It has solved the problem. I'll nurse the battery for awhile longer since I don't drive the vehicle that often. I will be interested to see how my Skoda Superb battery held up on the conditioner for 6 mnths in the UK. I'm still amazed at the mileage the modern diesels are getting there!
#30
#31
The cruise module was the cause of the error message. $2400 for the part, installed it myself and had the dealer enact and calibrate it for $130. No used units available and even if they were, the dealer would have to match and enable it. Unless of course you want to purchase the software package for $3300. Sucks but there are no alternatives.
rcode
rcode
rominempire
28
10-08-2020 10:39 AM
FS[NorthEast]: 2008 XJ Super V8 - Black on Cream
sg997tt
10-09-2015 10:57 PM
