intermittent headlight issue, plz help
swduke,
Still trying to figure this issue out myself. Hang in there, for me as I was saying... replaced the both HID headlights as well as the sensor on the dash. I heard that the sensor on the mirror might have something to do with the light flashing problem, but I thought that controled the windshield washers only??? I'm still hoping someone can clue us in to any other ideas or maybe a ground somewhere.
Jagitt
05 XJ8L White Onyx
Jagitt
05 XJ8L White Onyx
OK, same problems with the low beam HIDs everyone else is referencing. Started with the driver's side -- would intermittently go out at night, then back on. Then sometimes go for days or weeks and be fine. Then go on and off irregularly and frequently. Then the passenger side would go out and back on. Freaks you out first time both go out at night on a dark road.
Turning stalk to off and back on would help sometimes (especially at first), turning car off and back on usually did the trick -- sometimes for hours or days would be fine, sometimes start going off again almost immediately.
I tried not using auto mode -- no difference. I turned off daylight running light mode. No help.
In last week or so, passenger side is completely out -- so now I think that bulb is wasted. Fuses are good. Seems to me the sensor being intermittently bad would cause both lights to go out at the same time.
A few of times, even fog lights went out, and even scarier, have been driving with the high beams on -- and THEY went out at 70 MPH!
This is a dangerous situation! I discussed with dealer service folks and they want to check ballasts and the stalk. What is Jaguar USA doing about this? Does anyone know?
For my money it has to be a problem with the stalk. Anyone know how much the dealer charges for the parts and labor on that?
This problem is on 2005 XJ8L / 101K miles. The HID bulbs and ballasts have never been replaced.
Thanks!
2001 XK8 convertible
2005 XJ8L
Thanks!
2005 XJ8L
Ron
Mine did same thing on 05 XJ8L. Are these xenon or halogen? If xenon, just start by getting a new set of xenon bulbs and replacing those. Then if that does not help replace the ballasts. It might seem like both headlights are going on/off at same time but as things progress you will notice they can blink independently. There is a thread on here that provides step by step instructions with good photos on how to get access to the inside of the headlights from the back. It's what I used. Small limber hands are best.
Bulbs should be about $100 each at parts store or maybe $70 online. Ballasts should be $200 at the auto parts store. Sounds like a lot until you go to the Jag dealer - they do not replace bulbs and ballasts they want to replace headlight units and those are over $1200 each. The quote I got to replace both headlights was $3400. I spent $200 on a couple of bulbs and it took 40 minutes to change them. Burn in new xenons as directed!
Changing just the bulbs worked for me and been good for over a year.
I would not waste my time looking for another answer. I did and wasted a lot of time.
By the way I got my dealer service rep to tell me why they don't like to change bulbs and ballasts. It is because if you do not get the seal back in the right spot moisture can get into the enclosure. They will not warranty if they replace.
In a nutshell, my headlights, in auto or in the "on" position, sometimes flash on their own rather quickly. It is rare when it occures. When they go on and off, messing up, they flash on and off about 1 second off then back on, a second off then back on. It stops when I turn em off then back on. Like I said, it doesnt happen often. I rule out the sensor for the auto mode since it also happens when I manually turn them on. Any help would be appreciated. Oh, one more thing, it is not just one light but both headlamps.
