Intermittent SRS light / B2295 (29)
Have you grabbed the JTIS from the forum download area (also linked in many threads and found in the FAQ's at the top of subforum areas) it has a specific DTC section that describes each fault. i've attached the 2004 MY, and is pretty common to the xk8-xkrs of similar years, being the side airbag in the driver or passenger seat. In mine (indicated by the 2-2 blink code) it is always the connector under the seat OR the connector just prior to the air bag inside the seat back (found by pulling up/back the seat leather almost to the headrest. Last week, I cleared the intermittent fault by simply unbolting the seat rails, tilting it back, and unplugging/replugging the specific harness connector together several times. Light off ever since.
To find out which connector is yours, you'll need the electrical schematic for your car, the 2004 MY is linked here. Get the JTIS, its a lifesaver, and its free...just download and install. Link added here -> http://www.mediafire.com/myfiles.php#3297awvo3atgw
rsa760041
23
09-25-2015 01:33 PM
