Jack Points
RE: Jack Points
This car has micro sizedjackpoints! Right behind each little bulge in the rocker panel seam where the jack in the trunk fits, there is a bare metal area, jack there. If you have a special jack with a sort of nubby phallus on it, it fits in a hole in this metal area. I think the shops use this special fitting to keep the car on the derned lift. Look out in the rear, if you miss the jack point even a little, the jack will bend the lower sheet metal radius arm for the rear suspension, and you might be crabbing sideways from then on. I could bend these things over my knee! Reminds me of the arms on my Lotus Europa. I think this was just a little too light for practicality, they are going to get bent sooner than later.
Collector1
09-25-2015 11:27 AM
